Bootmgr is missing help please
slamcmy
ok im almost pulling my hair off and i dont know what to do im clueless, so lately im having this problem when i turn my pc on sometimes i hear different beeps than usual and then i hear a fan spinning loudly and i dont get any video, so i try ctrl alt del several times to restart and usually after 8 or 9 tries i get video and i get into the bios to see if its recognizing my hdd then after exiting bios i get the bootmgr is missing so when i try fixing it with my win7 dvd and booting from it it still says the same thing, i have formated my pc 4 times now, after i do that my pc works fine for 1 1/2 or 2 weeks then ill get the same error, so i dont know whats happening i dont know if its my hdd or motherboard video card im really lost here thats why im posting this here cause im clueless, BTW the pc im talking about is on my sign....please help, sorry if this doesnt belong to the motherboars channel but since i dont know whats broken here im not sure where to post it... ty for any help
usually boootmgr missing is an hdd problem if its hardware. the easiest fix for it is to put in your install disc and run the repair wizard, but if thats not working then its probably the hard drive. can you try another one?
yep, i would scan the hd first to see errors. my first thought is falling drive.
any software you recommend to scan it ?
This and a second thought is the PSU is not delivering clean power
what do you mean by clean power ? my pc is connected to a voltage regulator all the time, actually i just changed my old one and bought a new one like a week ago, i mean yes i hear some sounds out of the voltage regulator like the one i had before but thats what they do when there are low or high voltage coming in, it means they are regulating the voltage, so im not sure if you were talking about that when you said clean power, thanks for helping tho.
Meaning the PSU is failing or faulty. First rule out the hard drive and everything else you can, then if you still have problems you will need to RMA your PSU or get a new one.
but im not having BSOD on my pc or crashes its perfectly stable, it only happens sometimes when booting up, if it was the psu thing wouldnt i be having crashes or something like that while im playing or something, thanks for your help bro
Make sure you don't give up too easy on the hdd, I had a problem last week that was only solved by using the recovery console where I first made sure the partition s were ok with DISKPART then used bootrec with its different options. Good luck, the fact you see that boot mgr is missing means the drive isn't a total failure.
edit: sorry didn't side that the problem is intermittent. Check all cabling and reseat hardware just for fun.
