Boot-up with NO case?
TooEasy!
Has anyone tried this before? If so, how do you go about doing this? I'm trying to custom mount a mobo without case.
Yeah, no problem.
If you've got spare standoffs lying around then screw enough of them into the back of the board to allow it to sit on a surface (raised).
Blu tac/white tac is nice for sticking a fan or two around.
You can put screws in the base of the hard drive(s) to raise them as well, or if you happen to have a spare cage use that.
Position stuff so it's relatively neat and there you go.
Also might want to do it on a surface that you don't mind getting a little scratched (ie not a pristine desk veneer).
to power it on you can just use screwdriver to bridge the two power button header pins on your mobo.
i just put everything on a large cardboard box with parts hanging off the side :cool:
here is one of my folding rigs, running on my desk......been like that for about 4 months...:p
You could grab a power switch from an old case or order one online and cut it down really short so it's basically sitting on or near the MB
put the MB on the antistatic bag it came in.
plug in video card, power supply, memory and cpu.
short the two pins used to connect the power switch
you should see your computer boot
Great info guys! Just found a power switch online for $10. Would one see any problems mounting the motherboard to wood?
No, wood is fine. You could also just lay the board flat on the wood (as opposed to mounting it with stand-offs).
Are there any jumpers available to where I can just use the power switch on the PSU?
Usually there is an option in the BIOS to choose the behaviour when power is first applied. So once you have used a screwdrive to boot the board once you can go into the BIOS and set it to always power up when you turn the PSU on.
