Quick bondo question for the Mod gods? I did a huge amount of bondo work on some plastic, It looked good and I pained it using some rattle-can plastic only paint , I didnt notice that where I filled the floppy slot, there is a small crack that didnt show up untill I painted, Can I fill it with Bondo? ( will it bond with the paint? ) its only about an inch long and I still need to do another coat of paint.
Thanks.
Thanks.
