Just_Mexel
- Feb 26, 2013
Hi There, here Just_mexel with a new Casemod, maybe you know me and know a few of my little casemods, i am busy on 2 at the moment, waiting for parts and ideas, also a few RMA items, so i want to start a new one, this one is more simple, and the parts i need for it will be sponsored and a few i must buy for myself.
Well, here is the Blue Box, a cleen casemod with plexi panels, sleeving, UV lights, and watercooling.
The plan i to build the stryker with plexi panels, hide the cables and other parts, also do a clean watercooling setup, there will be a PSU cover, with a 250mm tube on top, pump and little 12cm tube will be on top, Only the CPU will be watercooled, GPU i must look for it when i have more budget.
After this one you will see a nice testbench buildlog.
Hardware list.
Asus P67 Sabertooth, just got it back from RMA, network chip broken.
CM 850 PSU
CM Storm Stryker
Phobya watercooling
EK waterblock CPU cooler.
Sponsors.
Not all items i was getting sponsored, a few i buy for myself, and some parts was a good discount. And my special tnx will go to them all.
Plextor will sponsor to, only waiting for a good image and banner, already have 1 SSD for myself, now waiting for a second one for this build.
Pictures.
The CM Storm Stryker, a very good and big case, love it
My old system, this one was only for a review and testing.
Simple sleeving job, just for testing my bad skills.
Inside.
The RMA Sabertooth, sending it to Asus, network chip broken, and i am now lost my I/O backplate, that was in the box to, did not get i back after the RMA.
Caseking box, with no Haribo candy this time.
This order was normaly for a casemod compo at Coolermaster benelux, did not go to round 2, and this box i also needed to make a few other plans, that why i am now building this casemod.
I dont use this any more :-(
Love Plexi.
UV plexi
Also 2 temp sensors for the build, this will be inside the case, in total i will use 4 temp sensors.
See ya at the next update.
Hardware list.
CM 850 PSU
CM Storm Stryker
Phobya watercooling
Sponsors.
Pictures.
Inside.
Love Plexi.
UV plexi
