budec said:Have everything go though a remote firewall or remote proxy.
FAH supports proxy (if I recall correctly) and setting up a proxy for F@H would be super easy. Could do this with a linux or windows machine.
QFTrogue_jedi said:easier than that.
run polipo. don't tell users that it is there, and set that in the FAH config file. you can probably block access to all but certain sites (get the list of servers from stanford, put that in, plus the 2 assignment servers)
put that between the internet and all the machines and you're good to go.
