First off, my apologies in advance if this is in the wrong area.
About a hour ago, I was just doing the normal stuff on my computer. Then without warning or reason, it gives me the blue screen of "physical memory dump" and all of that. So, I had to re-start. This isn't the first time this has happened. Only this time, after the Windows XP loading screen, it doesn't go to my user login. It just stays blank.
I'm obviously in safe mode now, and I tried a virus scan to see if that was the problem. Nope.
Any ideas as to what may be the problem? Any help is GREATLY appreciated.
Thank you.
Thank you.
