coolchu001
- May 27, 2007
Just got 2 of these cases (silver and dark gray).
The one I'm working on is the silver version since the gray one is coming in tomorrow.
![](http://img223.imageshack.us/img223/8530/dsc01660le8.th.jpg)
![](http://img182.imageshack.us/img182/9779/dsc01661fk5.th.jpg)
![](http://img182.imageshack.us/img182/7422/dsc01672ga5.th.jpg)
![](http://img513.imageshack.us/img513/5447/dsc01673ix6.th.jpg)
![](http://img513.imageshack.us/img513/889/dsc01674ba7.th.jpg)
![](http://img182.imageshack.us/img182/1069/dsc01676my1.th.jpg)
![](http://img169.imageshack.us/img169/6453/dsc01678ij4.th.jpg)
I used Duplicolor auto sealer primer and flat black. Here is the result after 3 days of drying and pre-fitting the front panel:
![](http://img301.imageshack.us/img301/1408/dsc01688st0.th.jpg)
![](http://img410.imageshack.us/img410/7656/dsc01689as6.th.jpg)
![](http://img410.imageshack.us/img410/79/dsc01692ov8.th.jpg)
![](http://img127.imageshack.us/img127/7425/dsc01694fv3.th.jpg)
![](http://img375.imageshack.us/img375/1103/dsc01696ha4.th.jpg)
![](http://img375.imageshack.us/img375/4483/dsc01693ss1.th.jpg)
![](http://img337.imageshack.us/img337/7157/dsc01698op4.th.jpg)
![](http://img375.imageshack.us/img375/9094/dsc01699xo9.th.jpg)
I definitely need to get another can and do a second coat since the first coat gets scratched easily. I need to spray the hard drive caddies as well since I ran out of paint. Perhaps I might do a thin clear coat after the second coat of flat black to protect the paint from chipping.
The last things I'll be doing is to paint the inside panels flat black and the outsides in a glossy smooth dark gray or mirror finish black.
