Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Which would be a better setup for low air flow / quiet: a black ice extreme II or a black ice pro II? I've heard that the pro actually is better under low air flow situations, can anyone clue me in? Thanks
the BIP2 is usually better than the BIX2 for low airflow situations as its fins do not have as much airflow resistance as the BIX2 -- hence, you can use quiter/lower cfm fans and still get decent airflow through the rad.
