Biostar T-Utility Overclock problems
RaZeR
I installed their T-Utility program off of the CD and when I launch it the program opens but i get an infinite amount of pop-ups that say "'0.0' is not a valid integer value" that spawn every second or so. Anyone have any ideas?
same happens with me. it worked with my 3500 winny but i swapped in a opteron 146 and now its n/g. also clockgen and systool dont work anymore.
Just use the bios. You can lose the registry by using the Tforce OC program. Its crap. Get a 02 bios for that Tforce. Then OCing becomes a walk in the park. Look at me.
He might not be using the 754 board.
Yeah. I just ended up using the BIOS. Running at 10x280 now.
