wayout2day
- Oct 15, 2006
customer came in with a laptop...HP Pavilion dv6000. 200gb running Vista hm prem...the PC would only boot to an opening screen with the green ribbon and Microsoft Corp under it....never to the desktop.
I pulled the HDD. Using a docking bay, I copied the pictures and documents to another PC.
The HDD interrupted the copying, stopped. I then stopped the copying and finished folder by folder. In Win 7, I used disk mgmt to delete the volume, created a new volume and started the format. The format hung up and stopped at 67%. I did not wipe out the recovery portion of the disk.
I then deleted the recovery partition, and reformatted the entire drive. It took time, but was successful.
I loaded Win 7, using my MSI U-100 netbook. (I removed the 160 GB HDD running WIN 7)
The program loaded fine. I restarted and noted that the windows 7 startup screen did not appear. It was the same Microsoft ribbon screen.
I re-installed the 160 GB HDD into the netbook. It also loaded the ribbon screen.
I used another HDD to load windows 7 onto the HP. I loads into the WN 7 startup screen and then properly into the desktop.
I was reading about bios level rootkits. This would involve flashing the bios on the netbook, and probably the HP, and low-level formatting the 3 hard drives.
Or did the mischief just change the gui boot up ?
ready to flash
michael
ready to flash
michael
