BIOS problems
Axiom7
I am having some trouble with my BIOS. When I go in to change a setting or something, and i would like to save and exit, I get propted the usual screen,"are you sure you want to save and exit? Y" And this is where I have my problems. I hit the y key and nothing happens. I hit all the keys and only ctrl+alt+del work to get from the bios. I look to see if it is frozen, but the num lock light comes on and off when i hit the key. I have changed and couple different keyboards, but they all do the same. no prob with kb. and help??
Mike
Umm this might sound stupid, but are you hitting the ENTER key after you hit Y?
Well the reaosn I say that is that I can't recall just hitting Y when saving BIOS settings, at least not in most Award based BIOS setups. You should have to hit Y and then ENTER. :)
Maybe you're just not hitting ENTER. :)
Axiom7 said:
in one instance I might have
lol, Are your clocking things up two high? try doing it at the defult settings and see if you get the same problem.
