I'd normally ask this question in the motherboard forum, but my focus is in F@H optimization. I have a Xeon motherboard and there are certain BIOS settings that I don't know if I should enable or disable. I'm more familiar with Opteron hardware, so bear with me if the settings might seem obvious to some with more experience.
Specifically, certain memory related options, and there seems to be a bewildering array of them, need elaboration.
Which if any regions of the memory should be cached? Currently, I only have the Extended Memory Area cached as 'wright back.'
What's Discrete MTRR Allocation and should I enable this?
What option should I select for SERR signal condition (none, single bit, multiple bit, or both)?
What setting should I set for Memory Branch Mode? Sequential, Interleave, Mirror, Single Channel 0? I currently have two modules but intend to install 4 modules, just waiting for responses here first. The interleave mode should be set at what ratio, 1:1, 2:1, 4:1? What about Branch Rank Sparing, disabled or not?
Should I enable or disable the snoop filter and Enhanced x8 Detection? What about the Clock Spectrum Feature, enabled or not? High precision Event timer, yes or no?
In the CPU section I have the Adjacent Cache Line Prefetch and the Hardware Prefetcher both enabled since I assume that's best for overall performance. What about the Intel Virtualization Technology? Do I need to enable this for installing VMs?
Some of these BIOS settings are probably familiar to anyone who has a Core2 processor-based motherboard, whereas others must be Xeon specific. If anyone can advise me on any of these settings with regard to F@H only, it would be immensely appreciated. Thanks in advance.
