BIOS external speed?
donkey33
I noticed an option on this under the advanced options.
Got an ASUS A7NX E-Deluxe.
The external CPU Mhz is set at 166 with the option to go to 200. Should I be playing with this if I don't know a lot about it or just leave it?
Just thinking that maybe my PC isn't running at full capacity.
Thanks
List your specs aka motherboard and cpu, you have listed the mobo, now tell us what cpu your using.
if you change that, you'll be overclocking your computer about 20% over stock ;)
AMD 2800+
Should I even consider this if it's classed as overclocking and I've never done anything like that before?
Just wanted to make sure it wasn't running under par.
I would say no, and if you want to do so, read up about it and make sure you understand the risks. If I was you I would just leave it at 166/333 and dont bother going upto 200/400.
If you really really wanna overclock, then look at the bottom of cf eclipse's post and then goto the links he has in the bottom of his sig, they will tell you what you should do.
But if you do, make sure your memory is capable of those higher frequencies, which I suspect that your ram may only be pc2700 which is suited for 166/333 and not 200/400.
In anycase, read up on it first.
Thanks.
I will read up on it but will most likely leave it. I think I have pc3200 but would have to check on that first.
With your A7N8X and an XP 2800, you should set your FSB to your RAM speed (ie PC3200 runs @ 200MHz) and adjust the multiplier to scale your CPU speed. Your current processor runs @ 2250 MHz (13.5 x 166Mhz). You could easily change your FSB to 200 MHz, but you would have to lower your multiplier down a little bit. Otherwise, it would run @ 2700 MHz. I used to run my old 2500 barton @ 200 x 12 for an easy 2200 MHz, which is the same speed as your cpu (and also happens to be exactly what the Athlon XP 3200 runs at). So if you want to mess around a little, just to see if you get a performance boost, Set your FSB to 200, and lower your multiplier to 12. Nforce 2 motherboards like to run @ 1:1 FSB/DRAM ratio. Whatever you end up doing, make sure you can run at 1:1.
