This is for cheap FAH machines, used servers.
Am I correct in understanding that the BIOS has a table of CPU ID's in it along with the clockspeed, multiplier, etc?
Is there something other than common sense stopping me from trying to edit that table using a hex editor, then reflashing the result? ie - copy the data from a 2.4ghz chip model into the 2.0ghz model entry? This assumes the only difference is rated speed. Like an Opteron 8356 > Opteron 8389? Or 6128 > 6140?
How do you know if the BIOS is compressed, and is there a tool to uncompress it?
Or is this just plain dumb?
