XXX-OWNEDBYME-XXX said:dude that card sux ass mine does 430/1.15 and still idles at 51 and under playing tribes vengence beta on max settings only goes to 62 and i use the basic fan that came with it!!
b.t.w. it pny so bfg's so called lifttime warranty can kiss pny fans
Elios said:heh yea id kill for a BFG atm
Filter said:why return it? its running how its suppose to. o/c is not a right. and just cause it dotn o/c to what you want to doesnt me the card is deffective.
Halfdead said:i have a 6800gt does 395Mhzcore 1.08Ghz memory
I was wondering if I bring it back to store will I be Lucky enough to get another one that does 400 1.1GHZ maybe few more Hz
what you guys think ?
3 days old 6800GT![]()
I have the same card and mine does 430/1100 with an NV5 cooler and AS5 a;pplied....if you used the autodetect clocks in the NV control panel DON'T....that card will go way over 400/1080....trust me!!!!Halfdead said:i have a 6800gt does 395Mhzcore 1.08Ghz memory
ozziegn said:why?
not to put down the BFGs or anything but they're arent as special as people might think.
other brands of the 6800 GTs (ie - PNY, Leadtech or Gainward) are just as good and sometimes even cheaper priced.
ozziegn said:why?
