what do you want to spend? The 770's are in the $200 range i think. You could get a pair of used 580s and a basic amp for that.EhJayKim said:any ideas for something a bit cheaper?
My HD590's seem to do fine without an external amp. They are lacking a little in the low bass, but the highs are to my liking.
Mister X said:That is the misconception in action.
And it's also why the bass is like that.
The common misconception is that low Z cans are easy to drive but the reality is they harder to drive because they typically require more current then High Z cans.
(high z cans need more voltage in comparison to low z phones)
Add an amp and guess what happens?
The bass tightens right up.![]()
