Basically I have a Dual PSU extension,
specifically this: http://www.frozencpu.com/products/5...ower_Supply_Adapter_Cable.html?tl=g43c241s627
One side is standard PSU plugs, that you can use the paperclip, and tool, but the other side are male pins, what do you guys use to remove those to sleeve them?
Thanks!
Thanks!
