Best Socket A Heatsink
I just got my thermalright slk900a today. I like it. Dropped my temps about 5c over my old volcano 11. And I used a much slower and quieter fan.
I was thinking a Thermaltake SILENT BOOST 'cause it's quite a bit cheaper than Thermalright (out of stock at newegg) and Zalman.
either the Thermalright SP-97, Swiftech MCX462-V, or Zalman CNPS 7000A Cu.
SP-97 on my NF7-S v2 cooling a mobile barton @ 2500mhz(200x12.5) 1.9vcore and max temps at load are 47C, not bad for air cooling IMO
and try svc.com before u buy it off of the egg. newegg is great and all and has its uses but its not the be all end all online store to get supplies from. i got my sp-97 from svc in the same amount of time and for 15bux less(at the time i bought it.) GL HF
