Best socket 754 mobo
mpegripper
i need to know what you guys think is the best socket 754 mobo, chipset doesn't matter to me. I don't really overclock (at most 300MHz). i was looking at the neo platinum, and the av8-max3 and av8 pro.
i've heard they all have problems in their own ways, but i just want the best, i'm gonna be using the hardware in my sig below, except cpu will be a newcastle 3200+ and i might change the audigy to an audigy 2 zs.
also, can i use a socket 939 mobo with a socket754 processor, i've heard of couple people say you can, but i'm not really sure about this, doesn't really seem so
TIA
I don't know about the rest of your question, but to this one, the answer is a resounding no. The number after the word 'socket' (i.e. 939, 754) refers to the number of pins that the processor has. You need the same number of pins in the motherboard as in the processor. Otherwise, it is like trying to fit a square peg in a round hole.
I look forward to reading people's responses to the first part of your question.
Hello,
My Gigabyte K8VT800 with the Via chipset has been nothing but rock solid and disgustingly fast. Ive had it for about six months.
Zachary
Epox 8KDA3J is cheap, fast, and stable. I'm currently using the + version which costs more and has extra SATA but that is the only difference and it is great.
