M
mfm
Guest
For the last 3 years our network has consisted of 2 PCs, cable internet service, a Linksys 8-port switch, and a Linksys BEFSR11 (1-port cable/DSL router). The 8-port switch was available at the time I needed a cable/DSL router, so I opted for the 1-port version (3 years ago, the price difference was $90/1-port vs. $160/5-port). This setup has worked quite well for us.
Anyway, we about to add a 3rd PC to the network, but it will be located in a room where it works best to go wireless. In addition, we will be purchasing a laptop later this year, which will also have wireless capability. Lastly, one of the older PCs just replaced will be rebuilt under LINUX (4th PC), where I plan to use it as a file and print server (and to learn LINUX!).
It would seem that I have one of two options (and I am open to any other suggestions you might have). The first option would be to add a wireless access point and connect it to the 8-port switch. That would leave the current network untouched while adding the wireless capability.
The second option would be to replace both the 8-port switch and 1-port cable/DSL router with a 4-port cable/DSL wireless router. That would simplify the network at roughly the same cost (maybe even lower) as the wireless access point. I question whether a wireless router is more stable than the fixed 1-port router we have been using.
Any comments or suggestions?
