Hi guys. I built a waterchill kit into my main rig about a year ago, and have really enjoyed the cooling capacity and silence that came with it.
Recently I've built up an HTPC for my livingroom and have undertaken to watercool that PC for the same benefits. I've gotten started by buying a case and some of the parts I'll need, and I've began some of the modding, but I need help picking out the last few pieces to make everything jive well. This project is really just something to keep me busy and to have fun with; so I am trying to do everything with a mind for budget, but I'd like to make smart choices instead of just getting the cheapest stuff available.
What I have:
77' bonneville HC with 3/8" barbs sweated on, will be mounted in the top of the drivecage.
skyhawk aluminium server chassis
4x coolermaster 120mm quiet fans ~43CFM each. (2 push, 2 pull - top exhaust)
10ft braided 3/8ID tubing from home depot.
swiftech 5.25" bay resevoir.
What I need advice on:
pump (don't really want to spend much more than $50)
cpu block (cheap but effective?)
relay methods if nessesary for pump
I was looking at maybe the swiftech MCP6000 block from frozencpu for about 40 bucks, and the danner mag 3 from petsmart for like $45
First question is, will the danner mag 3 be enough pump for this system? Also, if I run those CM fans at full speed will that be enough air flow to effectively dissipate the heat from the rad?
If ya'll have any suggestions on where to pickup cheap stuff, or anything I'm forgetting, I'd really appreciate any input. I'm not really a n00b with this stuff, but I never shy away from good advice. All the current specs on my HTPC should be listed below in my sig, but if there are any specific quetions, just fire away.
Thanks.
What I have:
Thanks.
