If the KVM is ps/2 only, does that exclude using a usb keyboard or mouse with a usb-ps/2 adaptor? Does it have to be STRAIGHT ps/2 connection?It does not allow you to connect a usb kb and mouse though.
Originally posted by lil layzie
When using a KVM switch, does it degrade video quality/performance? Since the video signal is passing thru more wires.
I've got that exact soho (usb, ps2, sound, mic) model at work, and i use a usb mouse with a ps2 adapter with no problems. Scroll and everything works like they are supposed to.b
Originally posted by Systray
I was looking at the Soho myself.
I have a usb optical mouse but using the ps2 adapter on it, I guess having the usb option isn't a bad thing but for the most part everything will be connected via ps2.
Will there be any issues using a usb mouse with a ps2 adapater on the Belkin Soho series? I've heard of other kvm having a compatibility issue with that kind of set up?
Thanks for the feedback
Oh yeah as far as cost concern, nothing over $250
