Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
how much are u looking to OC?
if u jsut wanna OC a few Mhz or what not i dont think the SP97 is necessary...its $50 or so right?
you could just go with the Zalman CNPS 7000A-AlCu (not sure if it fits ur Asus tho)
I got two of these Zalman's and they are awesome. I would recommend these over anything else unless you are doing a serious OC then go for watercooling.
