Best CPU cooler?
hi everyone!
what do you guys think is the best CPU cooler for my Intel P4 3.2 Prescott?
i was thinking of the volcano thermaltake 12? but that is only for athlons... :(
what you guys reckon the best one for me to get is?
with no budget limitations! :D
well, within reason
vapochill is a "tad" expensive :p
i am just looking for the one which will cool down my CPU the most :) (heatsink style, no liquid nitrogen stuff!)
A lotta people here aren't a big fan (no pun intended) of the thermaltake stuff. I'd go with a Thermalright or Swiftech heatsink and slap a nice Panaflo on it.
i second the thermalright + panaflow
pick up some AS5 also
if u want to OC then lap the HS
thermaltake SUCKS!!! please do not ever by their products.
Zalman CU-7000 is the best, imho... Otherwise get a thermalrite as suggested above.
I still say the zalman is king, however.
have you tried both heatsinks on the same rig to be saying that thermalright sucks?
you might wanna re-read that. he said thermaltake sucks, not thermalright.
damnit, agian i need to take engl for dummies. my mistake, i apoligize :(
rapidgaming said:
well i have heard some negative comments about zalman elsewhere but could be wrong. what are you idle and load temps with it?
is the thermalright pretty beefy?
here are my options then...
http://www.frozencpu.com/cgi-bin/frozencpu/cpu-swi-09.html <----Swiftech MCX478-
http://www.frozencpu.com/cgi-bin/frozencpu/cpu-tta-21.html <----Thermaltake pipe101
http://www.frozencpu.com/cgi-bin/frozencpu/cpu-tri-12.html <----Thermalright XP-120
so which one :D
My Zalman is keeping my 3400 CH @ 36*/42* ( stock speeds for now...until my OCZ 3200 comes )
i've got the thermalright slk-97-U with panaflow 92mm
my amd 2500 1.8 overclocked to 2.5 at 39c idle and 45c load, i think thats very impressive
which Thermalright should i get then, considering i have intel,
my options are:
SP-94
XP-90
SLK-948U
or the Swiftech MCX478-V - Socket 478
dont buy from frozencpu.. there prices are way higher then the egg $48 vs $37 (with shipping)
sp-94 cant be easly beat by anything if its setup right.... the zalman works nicely in my friends p4 but its a northwood
yusoweird said:
200w peltier + water
good point but i think he wanted to go air cooling.... he could peltier an air cooler easly enough tho
any thermalright will do, ocin or not. slap a panaflow on it and ur fine. include as5
A XP-90 with a 90mm 50cfm 30 dB fan with an air scoop that connects to the outside of the case?
Go with Thermalright, I don't know what these people are talking about...Zalman being better. The Thermalright cools better, the one thing the Zalman might have is that it's quiet. Though, with a Panaflo on the Thermalright, it'd win all out.
And if you end up with Thermalright, make sure you get a nice copper one :)
Zalman is nice and quiet, however on newer CPUs its hard to recommend over some of thermalrights offerings. I doubt you will see a low enough temp to even consider it unless you wanted a quiet computer without overclocking.
I donno, my Zalman ( at max RPM ) is keeping my 3400 CG clawhammer @ 2.4ghz ( 230x10.5) w/ 1.55v around 38*/43* Not bad considering I cant even here the thing. :)
IMO, I'd go with the XP-90 before the XP-120.
and if your CPU is an LGA775, Thermalright should be releasing a new version of the XP-90 compatible with the socket within the next few days (or so they told me).
