best cable sleeving?
yeah...for a unique/exceptional look you can also take a look at the Techflex Reflex Sleeving from performancepcs. the reflective threads glow across the room under an led light.
expensive, but it lasts for years.
I dont think it is the kit that is going to do the job really. Just about any kit is going to get the job done well. With good technique is really the key. About every kit I see is virtually the same, save the slight variance in thicknesses and length of provided thickness. I have used off the shelf kits and had stellar success. A bit of it is also patience and personal taste. Not saying MDPC dont do a great job, just saying the kit doesnt matter that much IMO. Follow good techniques and you will get great results. The subject on how has been covered at great length, so I wont cover here again. I would say there is someone weekly if not daily who asks about sleeving.
