BenQ 241W Problem
KLSsandman
Hi,
Just got my monitor, very pleased with it too, apart from when I connect it using DVI to my ATI 1950XTX's in crossfire, the screen will display in 2D, but in 3D I get a picture for 1 sec, then a blank screen for 10 secs, then 1 sec of display then nothing again for 10 sec and on it goes!
It does this at all resolutions.
Its works fine using D-Sub with the Crossfire cable.
If I disable crossfire and plug the dvi straight into a single gfx card, then that works fine too.
I used to use dvi on a Hanns G 19" TFT at 1440 x900 with no trouble using crossfire. So I'm not really sure whats to blame.
Anyone have any ideas?
Thanks
Simon
