beeping
chris88
well my system is togather minus my video card, so i figured i would turn it on to make sure all my fans are running, and my lights work. so i flip the psu switch give it a second or two, the red led goes on. i press the power button on my sonata and green led goes on, hsf starts to spin, regular fan starts to spin, the little fan that says abit starts to spin i here my hd start up. then it starts to beep. its like a second long beep with a few seconds inbetween.
what the fvck is this thing doing?
__________________
-abit nf7-s rev.2
-amd 2500
-volcano 12 heatsink and fan
-artic silver 5
-one stick buffalo tech pc3200, soon to be 2
-segate 120gig hard drive
-gigabite 9600xt
-pioneer dvd-r
-pc toys lights
-logitech mx duo
-logitech z560
-antec sonata case
You need a video card to run the computer....
it will beep at you if you dont have one
according to a link someone just posted on sharky, it is a memory problem. :mad:
If there is no video card, it will beep at you. Same thing goes if you pulled the memory and had a video card in.
I doubt it's the memory, get a video card before you do anything with it.
the beep code for missing video adapter is
beeeeeeeep--beep--beep.
if you're getting this one
beeeeeeeeeeep..........beeeeeeeeeeeeep
that's a memory problem. Try reseating the memory and/or testing it in another box.
::edited to add URL::
You might find this useful:
http://www.pchell.com/hardware/beepcodes.shtml
thats teh one im getting :( it does it in all slots to. hopfully it will go away when i put in my video card because the last thing i want to deal with is rmaing ram. if i do have to ram the ram, i will ask for a refund and get some different ram, mushkin level 2 black, or corsair xms?
