StellaTerra
- Oct 17, 2008
I've read multiple times on the 'net that using a AA battery as a stopper for a 1/2" hose would work, and it does, I used one for about a month.
Today I was stress testing my video card and looking at system temps. I'm not sure if what happened was due to the testing, or if it was unrelated, but I started feeling around in system to see if anything felt hot and I discovered something odd. Rivatuner looked good, speedfan looked good, the tubing felt cool so I assumed the coolant was good, the radiator felt fine, and then I touched something very very hot. I felt around only to realize that it was, in fact, the AA battery plugged in to the t-line being used as a stopper. My mind reeled for a second as I try to figure out why a component largely outside the normal cooling loop would be hot, and then it occurred to me: I was using a live battery cell, and somehow it was reacting!
I shut everything down and grabbed a towel and pulled out the battery. It was extraordinarily hot, and though it's difficult to gauge temperature with my hand I'd say easily above the coolant temp. I inspected the battery and realized that the bottom had rust on it and some white substance, and that the wrapper had come partially off during extraction.
It still feels hot right now, after 15 minutes, though I think it's a little cooler. Does anyone have ANY idea what's going on? Was it incredibly stupid for me to use it in the first place?
WTF?!?!
WTF?!?!
