nthexwn
- Feb 27, 2007
Hi guys,
I've found over the years that my temps are always higher than others with the same cooling. I'm wondering if this is because I apply my thermal grease incorrectly. I've always spread it out like this:
http://i.frazpc.pl/pliki/2002/artykuly/art468/14.JPG
I then try to place the HSF on top as flatly as possible and turn the HSF about 2 degrees in either direction to smooth it over before bolting it down. Is this correct?
BTW I've got a Zalman CNPS9500 and an Athlon 64 FX-60 right now that I installed that way:
http://img.photobucket.com/albums/v28/nthexwn/InternalCooling-1.jpg
My temperatures have been bordering 60 degrees celsius lately under load. That seems a bit high, which is why I'm asking.
Thanks!
-Alex
Thanks!
-Alex
