MadJuggla9
- Oct 9, 2002
im building a simple client to connect to a server via a socket given a hostname and a port. When i click "Connect and Send" I am telling it to send the request (GET /index.html for instance) to the server, then display the servers reply in a textbox called textBoxOutput.
It seems that it works perfectly as long as i dont mess with the ReadLine(). I tried an alternative method by sending bytes to from and array as characters to see if that would solve it. My program still locks anytime i try and grab something from the server
here is the code for my button:
like i said, it locks up once it hits the readline marks:
- textBoxOutput.AppendText(connectionRead.ReadLine() + "\r\n");
if i try
- textBoxOutput.AppendText("Unrelated Text\r\n");
then it works everytime.
any ideas? I know the problem lies in the connection somewhere but im not sure where. I get no compilation errors.
edit:
Code:
private void buttonConnectSend_Click(object sender, EventArgs e)
//setup some variables
String host = textBoxHost.Text;
int port = 80;
String request = textBoxSendString.Text;
//setup connection to server and send request
Socket connectionSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
connectionSocket.Connect(host, port);
connectionSocket.Send(System.Text.Encoding.UTF8.GetBytes(request));
//setup connection to receive bytes from server
System.IO.StreamReader connectionRead = new System.IO.StreamReader(new NetworkStream(connectionSocket));
while (connectionRead.Peek() > 0) {
connectionSocket.Close();
if i try
edit:
