BAM! Help
  • Thread starter Deleted member 88227
  • Start date
D
Guest
I created an account using the same email I use for everything.
Went to sign-up for new projects and clicked the magnifying glass next to WCG. Says it's checking for existing account then says incorrect password. I'm not given the option to enter a password anywhere.
Help?
I don't think you need to. Did you try clicking "My projects" to see if WCG is listed there>? I hardly use BAM!
I also don't have yet any bigger use out of BAM!
The only thing I managed is to see all three hosts under my user ID; so I think the are connected to BAM.
On the account page my CPID remain empty; tried to refresh multiple times
AMS is enabled
when try to signup to project it tells me: invalid password. But also didn't asked for one. Q: what password BAM is using for connection to projects ?
ok; in my case the alignment of all different passwords for the projects solved the issue; now the issue is: don't like it to have the same password everywhere
I did the same. Changed the passwords and logins the same across all projects. Was able to sync them up. It's so stupid.
Sorry guys...that is just the BOINC way. I don't like it either, but it has been brought up for over a decade here and there. Devs don't want to break everything re-coding and they don't get paid to develop anymore. So, it is all spare time and volunteers.
at least they don't need my credit card info for anything and 1password gave me a nice long stream of characters ...
If you want to use your CC info that Donate button is always there.
That's fine as long as you leave my credentials logged in. I'll take the free electricity!
That'll be the first thing I change.... Oh and add some watercooling.
Make brackets for the round Asetek waterblocks. I Made one for my AM3+ waterblock a long time ago.
