I have my Q6600 OCed on my Bad Axe 2 to 3.0GHz (333 X 9). At this speed I can run four instances of Prime95 using the large FFT tests for 24+ hours. However, when I try to run the blend test with one thread to check for RAM stability, the test always fails after a few hours. I've RMAed my RAM for a brand that's on the Intel compatibility list for this board, and that didn't help. I've also tried running the blend test with the RAM under clocked and with the FSB and MCH voltages maxed out. I've also tried setting the reference frequency to 333 MHz, but no joy (I can't even boot if the RF is set to 333 and the RAM is set to 800 MHz).
I'm about ready to send this board back to Newegg. But before I do, I was wondering if anybody with a successful BA2 OC could tell me what settings they are using for their processor and memory so I can try them. I'm beginning to wonder if I have a defective board since I've seen many reports of people hitting a FSB on a BA2 that's much higher than mine.
Thanks for your input.
