Backup Solution Advice
NyteBlade
Hello,
Currently I'm without any sort of backup solution (not a good idea, I know). On my main computer here, I'm running an 80 gig IDE HD. Most people ask me how I can live with that much space, but I seemingly have the need to reformat every 6 months to keep a nice, clean feeling :)
I have 2 real questions here. The first one is my motherboard is a K8N-E, and supports SATA. Given this thing is an AMD 64 3200+ and I'm not doing a whole lot of file system stuff, I'm guessing buying a SATA HD just for the performance upgrade probably wouldn't be worth it, correct?
The second is trying to find a cost-effective way to backup some data. I really don't have all that much to backup, but when I tried using a few DVD to backup before, for some reason everything was corrupted, which resulted in not-so-good data loss.
Is the most recommended way for casual backups buying a hard drive enclosure and a cheap IDE HD, buying some sort of external HD like a Western Digital my book, or just buying a few 8 gig flash memory sticks?
I'd like something reliable, durable (falling from the desk accidentally hopefully shouldn't mean the end of it), and at least reasonably sized. It probably wouldn't be used on the go much, but it'd be nice if I didn't need a forklift.
Thanks in advance!
Flash sticks are cheap, the 4-8 gig'ers are the sweet spot, for price/value, if you can get them on sale. They will be far more durable than a HD in an enclosure, being that they have no moving parts. Harddrives in enclosures work only as well as the hd. I'd recomend the seagate barracauda 7200.8 Retail, long warranty, good solid drives.
8gb flash drive would be very good for backup if that's all the storage you need. No moving parts = very good reliability.
Why not just buy another 80 and continually mirror the data that you want backed up?
an 80gb hard drive today is dirt cheap. Heck, buy yourself a nice 250 sata or something for less than 60 bucks and make that your primary drive, then push your 80gb ide as your backup meduim.
