M
mfm
Guest
I fully expect to get flamed or belittled for this one, but maybe I deserve it. For the last 5 years of using Win98/98SE on our two PCs, I have never purchased or used backup software. My solution has been, on a weekly basis, to copy the entire contents of the C: drive to another, physical drive in the system (both formatted with FAT32).
For the handful of times I have needed to perform a full recovery of the C: drive I would connect the C: drive and the "backup" drive to my other PC using a long 3' IDE cable. I would reformat the C: drive (along with installing the system files), and then I would copy the backup contents to the C: drive. Worked like a champ! (BTW, the swap file was on a separate partition).
This brings me to the present. I now have two Win2K PCs with drives formatted with NTFS. It is my understanding that my Win98 backup process (however convoluted) will not work with NTFS formatted drives. Is this true? If so, why? If the drives were formatted with FAT32, would my old procedure work?
BTW, I will gladly listen to all suggestions on how to painlessly backup AND recover the main OS drive that don't cost an arm and a leg.
