May 8, 2008 #1 S stain. [H]ard|Gawd Joined Sep 17, 2006 Messages 1,045 My CPU temp is 40c (tive or take 1 deg.), but the cores are inbetween 48 and 55c. Which should I be more concerned about? I'm probably going to be getting a nwe HS after I get my new job, so yeah!
May 8, 2008 #2 A aethelwulf [H]ard|Gawd Joined Nov 20, 2007 Messages 1,938 The core readings are what you need to look at. Are these temps under load or idle?
May 8, 2008 #3 S stain. [H]ard|Gawd Joined Sep 17, 2006 Messages 1,045 Idle. I dropped my voltage down to 1.26v from 1.4 (jeeze auto voltage) I haven't tested "load" temps yet. I have a feeling I need to get a TRUE or a Tuniq120
May 8, 2008 #4 L LuckyNV Weaksauce Joined May 31, 2007 Messages 96 use Coretemp to monitor the temps, you will see 4 individual temps, and they may differ by around 5C
May 8, 2008 #5 S stain. [H]ard|Gawd Joined Sep 17, 2006 Messages 1,045 I'm using Hardware Monitor. the 4 cores are 52, 52, 48, and 51c.
