laukinisvilkas
- Dec 9, 2009
Hi, before I begin I have no warranty (its still only 1 year old).
So it's summer here (Europe, the room temperature is at around 27-30 degrees Celcius) and my PC suddenly started to reboot without any bsod, it's just a reboot without any hardlock or anything like that. Well I scratched and first thought it was PSU but wanted to believe something was short-circuiting since I had many peripherals connected. It did not help
Long story short, when heat once again came (now) PSU once again started to reboot so I associated the two - the heat and the rebooting.
Lets just say the cooling of motherboard, cpu gpu and all my hard drives is not the problem...
The problem which baffled me is that even when idle it could have rebooted at random intervals (so even at around 100W).
The thing I see right now as THE problem is that the fan of AX750 never starts to spin. I have 3770k at 1.25V @ 4.5 Ghz running prime blend 8GB ram used and GTX 670 overclocked 680 PCB running MSI kombustor using ~110% power and it should be at the very least 350-400W and the AX750 Fan just does not start to spin. Right now I my own fan blowing the air through the internals and rebooting stopped.
The thing is I see that the fan should be aware of both temperature of PSU internal components and power consumption but it is not. Since I have no warranty I plan to disassemble the PSU to test if the fan is faulty but before I begin I want to ask if my thoughts about fan failing are correct? Or may it be the controller in the PSU itself?
Thank you!
Thank you!
