I had a X-Fi Fatality. When my XP 32 bit install went west I had to reinstall Windows from scratch and as I had a legit XP Pro X64 I decided to try that plus due to having 4gb X64 would use all the memory (whereas XP 32 bit doesnt). Even though there were drivers for X64 with the Fatality the speaker levels were terrible and on the whole the driver was pants.
Then I saw the Auzentech X-Fi Prelude and had heard that this was a reworked card with greatly improved drivers. Excellent ! So I got one from morecomputers.com for £115, bargain.
Installed it today and installed the drivers from the CD. Using the Audio console tested the levels and the sounds were superb. Great I thought just what I wanted superb. Then I thought I had better put the patch on. Oh dear.
I`m using Creative 5.1 speakers.I lost sound to the rear speakers altogether. Front left and right are really loud and the centre is quiet. Rear channels are then directed to front left and right and are really quiet.
It looks like they really screwed up the patched drivers. Also with having 4gb games crash still with the patch installed.
Therefore I have logged a ticket with Auzentech support to see if I get a response.
The only recourse I can think of is remove 2gb and use the drivers from the CD.
It looks like it could be a very good card, but it still has driver problems !
