Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
do you have any idea how to connect this connections? the cable-names just dont match.
is it even hd-audio or ac97? oO
thx for every help, im getting crazy.
hfx micro m2. i think it doesnt support hd audio.
thats why i switched to ac97 in the software.
i used the hd-audio-names of the mainboard, because the ac97 doesnt make sense with the nc-connectors. i think the manual is bugged. nc seems to be ground.
