What is that gonna do?If yes, you could check your Creative AudioHQ Digital "Digital Input" tab. Make sure either 'default' or 'Dolby Digital/DTS SPDIF In-decode' option is chosen.
Mister X said:Go the windows control panel and click the Audio HQ icon.
Click the settings tab and turn off the software decoder.
What is that gonna do?![]()
Changing the digital input settings on the card ain't gonna fix a problem with the signal it sends to the receiver.![]()
