Atom Powered Robot
Doh i thought it was Atom powered, I think what they meant to say was "atom® CPU controlled" I dont think a CPU can actually provide power.
Unless that Atom CPU is running some massively complex AI routine, this is an exercise in futility. There are cheaper, more power efficient CPU's (non x86) out there better designed for robots intended to run on batteries.
Using an x86 cpu may make it easier to compile code for it using higher programming languages. However, I would be more impressed with a robot running a multi-core ARM system running a custom linux build to accomplish the same thing with exponentially higher battery life over an Atom.
Very Cool!
Robots are almost here!
Maybe I can be lazy when I retire in 20 years.
