ATI9800 Pro overclock
How does the over clock work? Is it a program or service that loads with windows, or is it something happens at boot.... is it permanante until you go into the progrma and change it... reloading windows and such, stay at the same overclock. Thanks, John
Overclocking allows you to increase the speed your graphics card works at for increased performance in games. The general rule is to keep clocking higher until you see abnormalities in games, then back down to the highest level you can with the graphics normal.
