titaniumx3
- Aug 4, 2004
Hi I have a Radeon 9800 pro using the catalyst 4.7 drivers on an Asus A7V8X motherboard. I was reading a tweak guide and noticed that there was an 'advanced' smartgart utility (accessed by typing 'smartgart' in start>run box). The guide says that in this utility the agp write and read settings should both be on, but my agp write is set as off. I switched it on and it asked for a reboot and upon logging into windows it takes about 20secs and then the smartgart utility suddenly appears again but the agp write option is still switched off. I tried re-installing the via hyperion drivers but it still doesn't switch on.
I then flashed my bios to latest version but still no luck. I then uninstalled cat drivers (clean uninstall), via drivers and re-installed them but still nothing! I then installed latest omega drivers and still the agp write does not switch on, while the agp read does.
Any ideas???
Thanks!!!
Any ideas???
Thanks!!!
