Replaced my essence ST with the U7 and i have some problems.
The asio driver does not seem to work, i have xonar u7 asio set in foobar2k and the eq bars are moving but nothing gets outputed. Only Direct sound works. Used to work fine with the ST.
I have the thing connected via coax spdif to my dac, which then goes to my amp / speakers. With asio my dac would automatically switch to the correct khz setting the specific track was recorded at.
Using it via wasapi now but would prefer ASIO.
Also, at random times, when i stop playback a crackling sound remains in my speakers, repeting itself over and over. I have to switch the dac off/on or play something else to get rid of it. But it does not do that all the time, now it remains silent after stopping playback for example.
Weird, was not expecting so much trouble with this unit considering the essence worked perfect from day 1.
I have tried every driver avail, currently running the latest one.
https://www.youtube.com/watch?v=5m9F_AGYuwc
Noise goes off when i turn off/on the dac at the end.
Also, if you leave it long enough it will eventually dissapear (15+ mins though).
