Asus VW266H UPC code help
pp1111
If you have a Asus VW266H, can you please tell me your UPC code from the box?
ONLY DIRECTLY FROM BOX PLEASE!
Coz I try to search or on the rebate form the UPC code is different from what I see on the box.
Many thanks for your help.
Don't know what you mean? I just sent my rebate in w/ the UPC code cut off the box. What do you need "exactly".
On the rebate form, the UPC code is:
VW266H 610839999200 MIR $30
BUT on the box the UPC code is:
610839688326
Sorry, my upc codes match (form and box)........check your data!
