Asus p4c800 deluxe-e NEED help / changing PSU
Kahloq
Ok heres the thing, theres a little power lead coming from the stock PSU that came with alienware(bought in feb 04) that leads directly to a little connection to the left of the cpu socket. Looking in the mobo manual it says its a pwr_fan connection. Well, the new OCZ technology 520 PSU does not have that little connector lead. Whats it for and is it needed for anything or is just to monitor fan speeds in the PSU or monitor voltage rails. Seeing as its called pwr_fan, it wouldnt seem like it has anything to do with voltage rails. Should I be concerned that the new OCZ doesnt have this lead?
The connection to pwr_fan should be going to your heatsink, not the fan itself. pwr_fan is just that, supplying power to the fan ontop of the heatsink.
Therefore, your CPU shouldnt have anything else on it.. but your heatsink/fan should connect to the pwr_fan after you install the new CPU.
Make sure your CPU is compatible with the motherboard and that the heatsink will work with the new CPU.
Im not installing a new CPU im putting in a new Powersupply unit, The heatsink/fan has a seperate connection off the mobo and thats on the right of the pcu socket areaand its called cpu_fan. The one to the left called pwr_fan has a direct lead to the current PSU, but the new PSU does not have that connection line. This is why Im asking what its for, since its not connected to a fan at all.
