Manic_Midwestern
- Jul 23, 2007
I will add some pictures later, but here the forum open to ASUS MS238H owners/ prospective buyers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236075
Okay, I love this monitor, but here is my main issue: There is a definate color problem from a lower viewing angle. The monitor is choice and the color/ contrast looks amazing from higher or straight on angles, but as soon as you go down a little bit it starts turning YELLOW! Especially a problem because I sit in a la-z-boy at a tall desk. Solution: Build a custom mounting bracket.
I am going to be looking deeper into this in the next couple of weeks. If you own this monitor and are thinking the same thing, feel free to input. I will include any sketches i come up with and I hope others do too.
My goal is to keep it under $20 and maybe some how incorporate a bar speaker or side mount speakers(not included in budget) into the design.
