Asus K8V SE Deluxe *PROBLEM*
Aeturnus
Bad Trader
I'm posting for someone who recently bought the amd 3200+ k8v PROMO
First of all, when he switches his stand by power on his psu his system powers up automatically
then he gets a system failed cpu test
He has atx 12v plugged in, all of his cards are sitting right
Here's his full system specs
Asus K8V SE Deluxe
AMD 3200+ 64-bit 512L2
Ati radeon 9700 pro
512 3200 crucial
200gb hitachi
Quite a few fans
this is all on a 430watt antec True power
Try to reseat HSF unit. Make sure CPU Fan is plugged in. And you might want to try a different brand of DDR if that is possible....
hey i thought i should add some more info. my system was working last night, cycled it on and off testing fans and left it off. this morning power button didn't work. turned psu off and then on, automatically powers on...is it possible the hsf will cause the system to autoboot?
look/change your powermanagement settings in the bios. Think your lan is making it come on....... But it does sound like a powermanagement thing......
i guess i'll try the heatsink, btw i can't even reach the bios since it doesn't reach the point where it displays anything. also nothing's plugged in now except for the speaker, ram, cpu&hsf. strangely it still auto powers on even when my 12v atx cable isn't plugged in. previously it refused to boot without that cable...
The turn off automatically on problem is default on the K8V SE
It is due "Restor on AC Power Loss" being set to LAST STATE or POWER ON!
Rob
You read it wrong guys, it powers ON automatically not off, when he switches stand by power on it powers on
k thanx for looking and suggestions, called asus tech support, they recommend rma
