I've tried two different graphic cards, and it 'sounds' like the board is powering up, the green led light on the board comes on as well. Any ideas on what could be wrong?
I would clear the cmos using the procedure in the manual?
Also plug a speaker into the sound jack to hear the Asus post
reported. Could be your CPU or ram. What video cards did you
try?
I had the same issue. This board requires you to connect the 4-pin ATXV12 power plug to provide sufficient power to the CPU. Your power supply will have the plug and you just need to look at the manual to find where to plug it in.
