hi everybody. first off - i wanted to use the search-function, but it is disabled.
ok, just put together an a64 system with a 3200+/asus k8v SE deluxe mobo. i slapped in a new 9700 pro and had artefacts already in the BIOS so i thought the card was screwed. however, i wanted to make sure and put it into a system with an athlon XP/a7n8x and it looked perect in the BIOS (didn't bother to install drivers and stuff). is that a known issue with the k8v/9700pro? can it be fixed or do i have to swap vid-cards?
thanks in advance,
j
thanks in advance,
j
