Asus GTX 570 vbios update problem
issepower
Hi, I'm trying to update to the last vbios update that I found on the asus support website.
When i click on the .exe i get the error "your graphic card of current system does not match this vbios".
I know that in the past I did some things with nibitor to unlock voltage I think. And I also read that if you update to the latest Asus vbios you won't be able to manually update(nibitor i guess) the vbios because Asus locks it with the last vbios update.
Thank you
Wait for someone to dump it and then use NVFlash to flash it?
